820-3024 - PPBus_G3H fluctuating. NSFW warning.
gcain
Board had a little corrosion; refer to attachment. :eek:
After an ultrasonic, some flux, another ultrasonic and a stint in the oven it turned on and chimed, then switched off.
Now it spins the fans for a second or two, then turns off for a second or two, then on, then off etc. Eventually it slows down to just twitching the fans every few moments.
@ J6900 DCIN fluctuates from 16.28 - 16.80.
F7030 goes from 13.9v to ~3v, then back up.
C7200::1 goes from 13.9v to about 3.6v and back again.
gcain
PP3v42_G3H is stable.
U7000::17/18 = OL
U7000::27/28 = 20ohms
U2700 looked okay going by the photos I took.
R7050 is measuring almost 0ohms. (Whats the correct way to measure a current sensing resistor like this?)
R7051 is 3Mohm (nothing wrong there...)
R7052 is 0.1ohm
R7051 is obviously blown, but C7050 looks pretty suspect too; will replace both and report back.
gcain
Now I get no fan spin and F7040 is going as log as 1.8v.
Clearly I am on the right track, I can see now that it's cleaner a few traces are burnt / corroded away.
Will sort them next.
gcain
U7000 is getting really hot then it goes cools down for a second or two then gets hot again.
Should I replace it, or is this caused by an issue somewhere else?
gcain
OK will swap it out then.
I was wondering if it was trying to supply enough current to a capacitor that was shorting and giving up after a bit; then trying again.
Will swap it and report back.
gcain
Thanks for the extra info.
I swapped U7000, turned it on and something went SNAP, but I'm not sure what or where yet. :/
Might be too much wrong with this board after all...
