820-3115 1/4 fan spin
mooserov
Going through the rails, everything above pp5v_s5_LDO is stable, PP5v_s5_LDO jumps a bit when the fan pulses, from 4.89vto 5v. Every voltage below that pulses. Everything appears to be trying to come on. Is there a standard way of attacking 1/4 fan spin?
mooserov
area had a little water damage, went ahead and cleaned up from a donor just in case. Still has the 1/4 fan spin.
Yes, see if you can read the original first. ME region should be rescued if possible, you cannot just use a BIOS from another board.
