820-3115 A1278 - Intermittent green light, no display.
SamMac
Appreciate any and all help, thanks!
So I've got a logic board where the board turns on (and green light is displayed) randomly meaning I have to plug in and out the charger before it suddenly turns on. When the fan starts spinning the green light cycles from on and off every couple of seconds and then turns solid eventually the fan then spins at like maximum rpm (the chipset SLJBC gets really warm which I why I believe that might be)
In all cases (green light or no):
PPBUS_G3H is present.
PP3V42 is present.
No display in LCD.
Thank you,
Sam
Well if it gets much hotter than a good working board it is most likely dead. Compare to another board first.
SamMac
The component F9700 has 12.57V showing at the PPBUS_G3H and giving 1.8V which slowly declines at the PPBUS_S0_LCDBKLT_FUSED end. All the connections to the LCD_BKLT gives a value of around 1.42V
Also answering your question it does get hotter than a similar board.
I don't see why we should be checking the backlight fuse if this board is not booting.
I suspect the PCH is dead if it getting hot like that.
SamMac
Is there anything else I can check for to confirm that the PCH being dead is more likely?
Thank you.
SamMac
What would be the best way forward for this, buy the chip online or to use the chip from a similar donor board (from one that doesn't show similar symptoms)?
