820-3115-b 1.5v s3/s0 Fet
Gmorb
Remove U9410 and forget about thunderbolt, see if S0 rails come back.
wow that was easy. worked. is that area shorted or why was it preventing s0?
well that got the fan spinning but now the d3895 diode is smoking. im assuming i wont need it if i dont plan to fix thunderbolt guess ill remove that as well?
edit:after removing the diode the chip next to it u3890 smoked as well got a partial fan spin now im back to green light i noticed the smoke coming from the side with the t29 booster pins. removed the chip now im back at spinning fan. guess thunderbolt is fucked for good? it gets extremely hot where u3890 used to be.
Find where the heat is coming from Q3880 tends to short too and the caps around U3890, I hope it is not in the board.....
Gmorb
cant find anything heating up out of the ordinary the heat from where u3890 sits is no longer there and q3880 isnt getting hot. capacitors tied to the t29 bst boosters are shorting and both pins where u3890 sits are giving my meter a beep too. problem seems to lie in the booster?
