820-3115-B Graphic Distortion when pressure is applied on bottom of board
theodore
In the past few years I have come across a couple different 820-3115-B 13" 2012 Unibody MacBook Pros that have an interesting issue, The system will function just fine and pass all standard Apple Tests however when pressure is applied to the bottom of the logic board right under where the CPU is attached the screen becomes distorted and the system Crashes/Glitches and becomes unstable. Is this possibly due to bad solder points on the bottom of the CPU? Has anyone run into this problem and can shed some light on this issue?
theodore
Thanks for the tip, Looks as if this was indeed the issue. Now from what I have seen on this forum this issue is not repairable correct?
