820-3115-B no chime and no picture after bad Waterdamage
Fizzl92
Hello,
i have problems with an 820-3115-B. The board had bad water damage and no green light. I cut off the bad damaged Thunderbolt area, replaced the SMC and a lot of other stuff. Now it has a green light and turns on again. The remaining problem is that it beeps if i take the ram out (speakers are ok) but wont chime. Also it has no Picture and no Backlight (missing LCD_BKLT_EN ; i already exchanged LP8550 and the LVDS witch were damaged too) Could it be an SMC Issue (bad soldering or maybe bad SMC ; but it has a green light after the SMC exchange)? At this point i´m stuck.
Thanks for any help!
Well, at this point it can be anything that stops the board from finishing POST. Everything is alive else it would not beep. Corrosion somewhere or under SMC/PCH/CPU. Maybe remove firewire chip if there was crap there. Does not look very good at this point.
Could it still be affected from Thunderbolt? I "cut off" nearly everything from PP15V_T29 but there is still a short on that line. Could it be a bad soldering on the SMC i exchanged? Firewire Chip and area looks pretty clean still but if nothing else helps i´ll remove that chip too.
As I said this could be anything. Probably a short in the board from T29 rail. Bad SMC solder is possible, anything.
Thank you for the help. If i have the time i´ll practice a bit with this one. Not everything is fixable but it was my first SMC exchange and it worked, so i learned from it...
