820-3115 four beeps no boot
Dmitry
Hi there, not even sure where to start since there is no topic on internet taking about 4 beeps.
I have this mac doesn't turn on. no image, battery charged fans spins, all common voltages are at place. No water damaged. Never seen board so clean. costumer said best buy swap board for them few months ago.
I press power button, it has 4 peeps then repeats. I have tried RAM just in case.
3 short beeps and 1 little longer, then it repeats.
Any ideas where to start? I tried to plug all the flexes.
Dmitry
I haven't done macbook BIOS flash before. I am using TL866 programmer, I am getting an ERROR "OverCurrent Protection actions! External short circuit/IC reverse or damaged!"
I dont have other ICs to test it with. does it meen eeprom is damaged?
Dmitry
I have higher then normal resistance on EEPROM pins 3 and 8. I do get 3.3v there, so most likely bad chip?
Dmitry
I will look at programming part later on Tuesday.
for know I found the same donor board and took chip from there. MacBook works now (takes a little longer to post), can I just do that or something will not work? can you explain noobie. there is not much information online.
aprendiz
Moderator
If you leave it like that will have ME region problems, so read the original, upload the file to a file hoster and paste the link here...
TL866 programs these chips just fine. Try another chip if you have one. I have no idea about this Ebay chip, but I would not trust them.
Dmitry
Sorry, it is 4 beeps. I typed it on autopilot. I ordered pre programmed chip from ebay, should be arriving soon.
It will probably have a used ME region, so the board will run slow or not fully boot. You really need to program your own chip for this.
