820-3115 ppbus - 12.28V
MDY
This board will not power.
PPBUS - 12.28V
SMC_adapter_en - 0V
Green light present
SCL and SDA at battery connector at 3.48V
I replaced ISL6259 and later SMC with same one from same board and I have still PPBUS - 12.28V
Anything more I can check?
It should power on with PPBUS at 12.3V anyway. SMC issue is suspected. What is diode mode on both data pins on the battery connector?
Customer told me liquide damage 2 month ago and somebody repaired lvds connector. It works 2 months and 1 week ago didnot power anymore.
Well, I forgot to tell that before replacing the SMC first time I had 1V at pin 4 and 3.48V at pin 6
After SMC was reflowed and later replaced I had 3.48V in both 4 and 6 pins (battery connector) scl and sda.
