820-3115 wont power
Glenn
Have a 820-3115 that wont power up.
Have green/orange light in magsafe
ppbus_g3h: 12.49V
PP5V_S5 : 5V
Missing s4 trace
(History the owner just told me that it died under OS install) no sign off water damage.
BMarden
Hi Duke, I am curious. How are there pulses on PP5V_S3? Would they not get filtered by C7290, 91, 93? Would the pulse freq. be the 300KHz PWM freq? Thanks
Glenn
I was a little careless when I turn the card, magsafen hit the network connector and that resulted in no lights in the magsafe
Glenn
PP5V_S3 give me nothing (0.0V) on the multimeter ( I tried a couple of times)
R1800 (Pin1) 3.32V (Pin2) 3.22V
R1801 (Pin1) 3.32V (Pin2) 3.04V
R1802 (Pin1) 3.32V (Pin2) 3.31V
R1803 (Pin1) 3.31V (Pin2) 3.31V
Glenn
No short on the s5 rails. I dont have scope so need to buy som LED tomorrow and try with.
Also inspect closely for corrosion, these boards rarely fail on their own. Measure voltages on C1802/3 as the trace can corrode too.
Is SMC_ADAPTER_EN present?
Glenn
No Title
Found something here.
Will measure voltages on C1802/3 and check SMC_ADAPTER_EN
now i will chek PP5V_S3 with light diode and report after
Glenn
No Title
No pulse light on pp5v_s3
C1802 Pin 1 3.33V
C1803 Pin1 3.33V
R5085 Pin1 3.43V
Glenn
Thank you for replay louis. It's too late i blow smc away ? Waiting for a new one. Then i will try replace u2600.
See there is missing 2 trace under smc 1 is UC and second is GND_SMC_AVSS it is 3 off thes under smc and all off them goes to the same place so is this one important?
