820-3208 Liquid Damage Green Light -> No Green Light
Just got in a board that had some heavy water damage to to the board near the LVDS connector. 2 Pins are actually blown off, came in with a green light, after unplugging the battery it would then go from green to orange. Put the board through the Crest and came out with no light on the charger. Checked the ISL area SMC_RESET_L is 3.38v. Tried removing edge bonding and reflowing the SMC no luck.
aprendiz
Moderator
Voltage at SMC_RESET_L? Seems SMC is not working, maybe corrosion/crap under SMC, if SMC_RESET_L is high put some flux to smc and apply heat to remove crap..
aprendiz
Moderator
Still 8.13V on PPBUS_G3H? could be corrosion on IO connector motherboard side or corrosion under battery connector.... measure data lines on battery connector in diode mode....
