820-3209 short on L7510/7550
arnonabuurs
Hi guys I have a Macair 820-3209 that came in with the problem that it didnt boot pass the Apple logo. Board looks very clean green/orange light & chime. After a check around the CPU i found both L7510 and L7550 are short to ground.
PPVCORE_S0_CPU = 0.83v
PPVCORE_S0_AXG = 0.97 and drops to 0 a few seconds after booting.
When following the lines in the schematics they didnt lead to anywhere, assume they both feed the CPU so its safe to say the issue is the CPU or should I check something else first? I assume these lines both link to the CPU and thus are both shorted and no need to test all resistor on each line? Please enlighten me, im not good fixing CPU issues and usually end up replacing the board :(.
If you have voltage there is no short, a low resistance yes, wich is ok, but no short....
AXG is only present when internal display is detected..
Hold alt key and try booting from a external USB drive...
