820-3332-A plenty of ASD Errors mostly GPU related
Davis
Macbook pro 15" 820-3332-A no liquid damage or anything, seems to work fine but plenty of errors from ASD related internal GPU and some others, heres the full ASD log:
Local machine info: Mac OS X version = 10.7.4(11E2510) IP Address:127.0.0.1 ASD version:3S150
ASD Log activity from [12/31/14 16:03:34] to [12/31/14 16:20:40]
[12/31/14 16:04:01] Chipset: Dmi Error Check (test #25) - Dmi Error Check
- Checks for Dmi related errors.
[16:04:01] ERROR - -12105 [PCI driver IOService open error] -- TEST FAILED
[12/31/14 16:04:01] Display: EDID Checksum Test (test #30) - EDID Checksum Test
- Calculate EDID checksum
[16:04:01] Test Passed
[12/31/14 16:04:01] Multitouch Track Pad: Multitouch Trackpad Open Test (test #8) - Multitouch Trackpad Open Test
- Detects potential digital opens by reading unbaseline raw data and making sure no consecutive high readings.
[16:04:03] Test Passed
[12/31/14 16:04:03] Current (IC0R) -- CPU <Core, GFX, DDR3, 1.05V, VCCSA> (test #1) - Sensor Reads Within Operating Range
- Check to ensure that sensor reads within operating range.
[12/31/14 16:04:03] Current (IC2C) -- CPU System Agent (test #1) - Sensor Reads Within Operating Range
[12/31/14 16:04:03] Current (ID0R) -- DC In (test #1) - Sensor Reads Within Operating Range
[16:04:04] Test Passed
[12/31/14 16:04:04] Current (IG0R) -- GPU Core (test #1) - Sensor Reads Within Operating Range
[16:04:04] ERROR -- 3 [Sensor reading below low point] -- TEST FAILED
[12/31/14 16:04:04] Current (IG3C) -- GPU FB (test #1) - Sensor Reads Within Operating Range
[12/31/14 16:04:04] Current (IM0C) -- DDR3 (test #1) - Sensor Reads Within Operating Range
[16:04:05] Test Passed
[12/31/14 16:04:05] Temperature (TC0P) -- CPU Proximity (test #1) - Sensor Reads Within Operating Range
[12/31/14 16:04:05] Temperature (TCXC) -- CPU Core PECI Temp (test #1) - Sensor Reads Within Operating Range
[12/31/14 16:04:05] Temperature (TG0D) -- GPU Die - Analog (test #1) - Sensor Reads Within Operating Range
[16:04:06] Test Passed
[12/31/14 16:04:06] Temperature (TG0P) -- GPU Proximity (test #1) - Sensor Reads Within Operating Range
[12/31/14 16:04:06] Temperature (TM0P) -- DDR3 Proximity (test #1) - Sensor Reads Within Operating Range
[12/31/14 16:04:06] Temperature (TP0P) -- PCH Proximity (test #1) - Sensor Reads Within Operating Range
[12/31/14 16:04:06] Temperature (TW0P) -- AirPort Proximity (test #1) - Sensor Reads Within Operating Range
[16:04:07] Test Passed
[12/31/14 16:04:07] Temperature (Ta0P) -- DC-In Proximity for Air Flow (test #1) - Sensor Reads Within Operating Range
[12/31/14 16:04:07] Temperature (Th1H) -- Right Fin Stack Proximity (test #1) - Sensor Reads Within Operating Range
[12/31/14 16:04:07] Temperature (Th2H) -- Left Fin Stack Proximity (test #1) - Sensor Reads Within Operating Range
[16:04:08] Test Passed
[12/31/14 16:04:08] Temperature (Ts0P) -- Palm Rest (test #1) - Sensor Reads Within Operating Range
[12/31/14 16:04:08] Voltage (VBLC) -- Backlight (test #1) - Sensor Reads Within Operating Range
[12/31/14 16:04:08] Voltage (VC0C) -- CPU V Core (test #1) - Sensor Reads Within Operating Range
[16:04:09] Test Passed
[12/31/14 16:04:09] Voltage (VC2C) -- Backlight (test #1) - Sensor Reads Within Operating Range
[12/31/14 16:04:09] Voltage (VG0C) -- GPU V Core (test #1) - Sensor Reads Within Operating Range
[16:04:09] ERROR -- 3 [Sensor reading below low point] -- TEST FAILED
[12/31/14 16:06:33] SATA: SATA PCI Register Test (test #1) - SATA PCI Register Test
- Checks the SATA link error registers for dropped data packets using direct PCI access.
[16:06:34] ERROR - -12105 [PCI driver IOService open error] -- TEST FAILED
[12/31/14 16:14:48] Video Controller Internal (test #2) - OpenGL Point Test
- Render Points
[16:14:48] ERROR - 80000003 [Unsupported] -- TEST FAILED
- Render Points
[16:14:58] Test Passed
[12/31/14 16:14:58] Video Controller Internal (test #3) - OpenGL Line Test
- Render Lines
[16:14:58] ERROR - 80000003 [Unsupported] -- TEST FAILED
- Render Lines
[16:15:05] Test Passed
[12/31/14 16:15:05] Video Controller Internal (test #4) - OpenGL Triangle Test
- Render Triangles
[16:15:06] ERROR - 80000003 [Unsupported] -- TEST FAILED
[12/31/14 16:15:06] Video Controller Internal (test #4) - OpenGL Triangle Test
- Render Triangles
[16:15:13] Test Passed
[12/31/14 16:15:13] Video Controller Internal (test #5) - OpenGL Quad Test
- Render Quads
[16:15:14] ERROR - 80000003 [Unsupported] -- TEST FAILED
[12/31/14 16:15:14] Video Controller Internal (test #5) - OpenGL Quad Test
- Render Quads
[16:15:21] Test Passed
[12/31/14 16:15:21] Video Controller Internal (test #7) - OpenGL Rectangle Test
- Render Rectangles
[16:15:21] ERROR - 80000003 [Unsupported] -- TEST FAILED
- Render Rectangles
[16:15:29] Test Passed
[12/31/14 16:15:29] Video Controller Internal (test #8) - OpenGL Cube Test
- Render Cubes
[16:15:29] ERROR - 80000003 [Unsupported] -- TEST FAILED
- Render Cubes
[16:15:36] Test Passed
[12/31/14 16:15:36] Video Controller Internal (test #9) - OpenGL Cube with Fog Test
- Render Cube with Fog
[16:15:37] ERROR - 80000003 [Unsupported] -- TEST FAILED
[12/31/14 16:15:37] Video Controller Internal (test #9) - OpenGL Cube with Fog Test
[16:15:44] Test Passed
[12/31/14 16:15:44] Video Controller Internal (test #10) - OpenGL Wireframe Model Test
- Render Wireframe Model
[16:15:45] ERROR - 80000003 [Unsupported] -- TEST FAILED
[12/31/14 16:15:45] Video Controller Internal (test #10) - OpenGL Wireframe Model Test
[16:15:53] Test Passed
[12/31/14 16:15:53] Video Controller Internal (test #11) - OpenGL Solid Red Model Test
- Render Solid Red Model
[16:15:53] ERROR - 80000003 [Unsupported] -- TEST FAILED
[16:16:01] Test Passed
[12/31/14 16:16:01] Video Controller Internal (test #12) - OpenGL Solid Red Model with Fog Test
- Render Solid Red Model with Fog
[16:16:02] ERROR - 80000003 [Unsupported] -- TEST FAILED
[12/31/14 16:16:02] Video Controller Internal (test #12) - OpenGL Solid Red Model with Fog Test
[16:16:10] Test Passed
[12/31/14 16:16:10] Video Controller Internal (test #70) - Fragment Instruction Test
- Tests each instruction of the ARB fragment program instruction by doing calculation and comparing actual against expected
[16:16:11] ERROR - 80000003 [Unsupported] -- TEST FAILED
wanted to ask how can i be sure that it is ASD false errors but then im thinking to give it AHT and see what will be the results..updating.
