820-3332 Macbook 15 retina 2012 CPU throtle / low performance
Noguinfor
Hi, working on an Macbook pro 15 Retina ( 2012 ), the computer works perfectly, but if i put to geekbench or other benchmarking software, the multicore score is low (average for that model is arroud 10000 but it only performs like 5k, the single core is correct.
The other problem is that the CPU temperatures is instable, i can work for like half an hour and its all perfect, but sometimes it starts to raise fan speed and with some software to measure temperatures, it raises like 20 30ºC in 1 second and goes back to normal and when this happen, the cpu reachs to 105ºC and starts throtling.
Since is a common problem i already resolder the U8900 but the results are the same.
The computer dont have any liquid damage, and of corse i try with fresh OS install and replace thermal paste.
ASD or AHT dont show any errors
Bad heat pipe also happens on these. See if the heat pipe is conducting heat well when system under load.
