820-3332 no fan spin no chime, mouse lights up
Repairable
came in with water damage around u7000 repaired some traces and replaced u7000.
after that I took the board to Louis and it just turned on,,, around the right fan where its connected to the board the screw bracket is broken off.
today I had some time and picked up the board again,.
found a short on u5850 after replacing it short is gone.
now I also have pm_slp_s4_l back.
no fan spin and no vcore
CPUIMVP_TON both resistors measure good 181.9k and 182,1k
also when measuring from the pin 1 red and pin 48 black 364k
any idear where to go next.
no cpuvcore
PP3V3_S0 present
u7950
pin 1 0.021v
pin 2 0.064v
pin 3 0
pin 4 0
pin 5 0
pin 6 0
pin 7 0
pin 8 3.3
missing CPUIMVP_PGOOD
missing ALL_SYS_PWRGD
CPUIMVP_PGOOD comes from u7400
pin 46 5v
29 5v
19 5v
CPUIMVP_VR_ON enables the u7400 chip
CPUIMVP_VR_ON comes from ALL_SYS_PWRGD
q7950
pin 1 0.002v PP1V05_S0_VMON
pin 2 un NC
pin 3 0.020v ground
pin 4 0.020v ALL_SYS_PWRGD
pin 5 1.068v VMON_3V3_DIV
pin 6 3.27v PP3V3_S5_VMON
pin 7 0 PP1V5_S3RS0_VMON
pin 8 2.7v NC
ALL_SYS_PWRGD, cames from the point where R7967 is tied to R7963-R7969, if one of the PGOOD signals is not coming high this will pull down ALL_SYS_PWRGD.... Measure big coils and check what voltage is missing.....
oke wanted to measure today, I pluged in the board and had 0 on the first few resitors.
I then stoped and went back to the power lines.
when I came to PP3V3_S0 I got 0 at probing one of the caps.
when I released the probe the fan started to spin.
I then unplugged to see if I could reproduce. tobad no.
but now I don't have any volts at
PP3V3_S3 0.020v
PP3V3_S0 0.094v
I got 3.34 volts at PP3V3_S5
SMC_LID 3.4v
horrible,, second time the logic board is just booting and gives fan spin while measuring around, even thou totally different place. then disconnecd charger and no boot again..........
Corrosion somewhere. Impossible to remotely diagnose, inspect all areas that had corrosion. Maybe under SMC if there was corrosion there.
