820-3437-b
Aaron
Machine won't turn on/display, Board has short fan spins, magsafe light is orange.
- C1910 Was corroded, so I replaced it and ran a jumper (picture)
- PPVRTC - Voltage is low. Has 3.42, but has drops on the line to about 2
- Voltage at C1910 is 3.42
What other information can I get for you?
I have working board the exact same here to help trouble shoot
Thank you
Aaron
- PPBUSG3H - 8.58 with drops to 8
- PP3v42 - 3.42V consistent
- C1910 - 3.33-3.42 (moves around)
- Pin 1 on U1900 (PPVRTC_G3H) - 3.33-3.42 (moves around)
- Pin 13 on U1900 (PPBUS_G3H) - 3.42
U1900 has not been replaced
Aaron
Thanks Duke,
I removed U1900 and found this (Picture). Not sure if the tear is a big deal. Will continue by replacing U1900
Aaron
Thanks Duke
- The fan has spun up to full a few times while sitting on the desk.
- pm_slp_s4l is pulsing as is S5l
- CPU heat sink is getting real hot
- U1900 has been replaced now, no change
- I checked around "U1900
, U1950, U6100 area termination resistors and traces, J6100, crap under SMC"
I will proceed by double checking these areas. Any other suggestions?
Thank you
Aaron
Another clue...
When I first plug it in, I get no fan spin. If I plug it in again, then I get short fan spins
(All measurements previously were taken with short fan spins)
I decided to measure the rails when there's no fan spin. I get S5 rails, but no S4.
Also Missing:
- S4_pwr_en
- PM_slp_S5_L
- SMC_S4_WakeSRC_EN
Sorry for the confusion
Aaron
Thank you.
Duke I found blue corrosion on the line to Q8150 (Photo), Replaced Q8150, nothing changed
WIll follow your instructions
