820-3437 keyboard & trackpad not working light liquid damage
Glenn
Have this Macbook air 820-3437 with no working keyboard and trackpad. board is light liquid damage.
Have tray a know good trackpad, keyboard and cable but still not working.
measurement on j4800:
Pin 19: 3,4V
Pin 14: 5,15V
Pin 10: 2,13V
R4830 2.09V and 0,1Ω diode mode give 0.367
Have test with a usb bluetooth mouse and that work
will test if it work when pressing down options button when startup.Nothing happens when pressing options button at startup just booting as normal.
No, that would fry R4830.
Is there 3V on R8050? If not check 3V on R5294 pin 1 (yes it is not on the board but test that pin)
Duke: Are you sure, don't you mean R8000 and not R8050?
R8050 is the PP3V3_S4SW_SNS
R8000 is the PP3V3_S4 Rail
It may also be something wrong after R4830, if you remove it and you get 3.3V you know where to look. C4800 or trackpad connector next.
There may be other places where the voltage on the rail can be pulled down, but you need to start somewhere
