820-3437 powers on, no backlight and no green light
Puevig reven
I have a water damaged 820-3437 that powers on, there is backlight for a sec then it turns off and also there is no green light. I have replaced LP8550 already and also ran a trace from ball 5 on LP7701 to pin 1 of C7796 because I thought I had a bad feedback trace. (Any suggestions on an easier way to measure for a bad trace besides continunity mode from eah side of the board would be great). After that I still have backlight for only a sec and I am still getting 8.5V on backlight circuit. Please help!!
It normally gets pulled down when you close the lid. The sensor is in the lio board thats why duke says you should try with another one. But if thats not the case then in more rare situations it could also be the trackpad (or ipd connector/cable) or SMC or C4835.
But start by measuring SMC_LID to check if its high or low to see if it is because of this or not.
