820-3462 sound works for 1sec then stops.
george-a
Hi guys,
This one plays sound for 1sec and stops. If you wait a while it will play for another second and stop again... I already replaced the audio codec but the problem remains. I focused on the audio codec since there are more than one amps and I thought that it can't be all of them failing.. (unless they have something common as a voltage rail?)
any ideas?
george
arash
Yes please check if it switches to optical(look into the port, if the red optical lamp is on). sometimes that is it.
george-a
so it has the same behaviour with headphones.. the sound comes up for half a sec and then stops.. if you wait a while it can work again for another half-second..
there is no light shining from the port indicating a working optical SPDIF output...
any ideas?
