820-3476 Charging issue
ielectron
I have another macbook with charging issues it was after liquid damage in keyboard back light area. I fixed display issue.
I already replaced battery and port they are fine.
Once i connecting charger to the laptop orange light came up but in system laptop shows information battery is not charging.
I measure voltage around port connector and compare to second laptop with is charging fine on diode D7005 pin PPVIN i have only 0,6V , working one have 12V.
Any idea where I should start with it?
Thanks
You replaced the ISL while there is no voltage at D7005....Issue is more likely around Q7010, check voltage there.
