820-3476 different one no io board
Repairable
Hi all, got in a MacBook 820-3476 this one does not reconize USB from the io board.
wifi works
hdmi works also
tested differnt cables and io board all the same
j9500 pin4 5.15v
pin3 3.344volt
XDP_USB_EXTA_OC_L 3.278v
XDP_USB_EXTB_OC_L 3.276v
XDP_USB_EXTC_OC_L 3.268v
XDP_USB_EXTD_OC_L 3.268v
had a short moment of usb mouse light, but only 1 time ....
There is nothing more to this. Just 2 data lines, 5V and the over current protection. Could be a bad USB port on the PCH. You did check for stable 5V under load by plugging in a USB HDD to see if it spins up?
USB_5 seems to be free on the PCH, if the test points are accessible then you could wire them to the bad port.
