820-3476 missing PM_SLP_S4_L
Status
Not open for further replies.
Fizzl92
That was at 50 mV/div and 5 us/div. All_SYS_PWR_GD shows a different behaviour. If i connect the adapter it just has a single pulse to ~3 V but it is so fast that i cant capture it. After that its back to 0 V.
The 3V spike on ALL_SYS would suggest the board tries to power on once. I still suspect a short on a rail or possible corrupt BIOS.
Fizzl92
I measured the resistance of all rails and added the values to the table. The new values are blue. I added a picture. I will try a new Bios chip today too and let you know if that changes something...
You read it with programmer. The chips on some of the China boards are erased. If it was a donor that was not from China then it is probably fine.
Fizzl92
I put the original Bios IC back on and read the china Bios with my progeammr and a new small PCB where i can solder these Bios ICs on. It is not empty and can be read without any errors.
Fizzl92
No Title
No problem. Thank you for the outstanding help. Even if it it may be dead i could learn the troubleshooting process.
In the mean time i got another 820-3476 in (i could fix this one and it still works fine). So i took all resistance measurements again from this working board, added the values to my sheet and uploaded it here. Only PP5V_S4 and PP5V_S0 are noticable lower than the values from the working board. So maybe this could be the last chance for this board...
Fizzl92
I have no explanation for this! No idea why PM_SLP_S4_L was missing. (this signal is really confusing to me) But i followed the lower resistance values (even if the diode mode readings were the same - i also dont really understand how that could be) and there are only three places where PP5V_S4 and PP5V_S0 meet. And only U8080 makes sense here. So i replaced U8080. The diode mode readings did not change but the resistance readings came back up and - i could not belive it- the board turns on. So i dont know what to say at this ponit except thank you very much for your great help and patience.
You and this whole forum are amazing!!!
SMC_ADAPTER_EN is ok, ppbus is ok,PM_SLP_S4_L is pulsing ! PPVRTC is ok!
Sorry and let me know if i have to open new topic, and i will!! Sorry but this case is very very near to mine!!
Thanks
Status
