820-3536-A J7000 connector source?
galvestonmac
Anyone have a recommendation for replacement J7000 DC in power connectors for the 820-3536-A? The 6 pin connector on the logic board, not the DC IN board. Thanks!
galvestonmac
Right, got that covered. I'm looking for new ones that have NOT been soldered on the boards yet. I haven't have much luck with trying to reuse connectors that come from donor boards. The plastic usually warped and melts and becomes un-usable after removing it.
If you cannot remove these connectors without destroying them you have some soldering to practice. It should be absolutely no problem. Use bottom heat and go slow with top heat.
