820-3662 Random Shutdown
Ryanlen2
Have this board that at the beginning was shutting down very randomly. Had a minor hint of liquid on C2643. Replaced it, and its still shutting down very randomly. Come to find out that its not so random after all.
When board is plugged in and its running, if i tap my finger in the U7600 section thats when it shuts down. I have reflowed the area and I dont really see how tapping on that are would cause the shutdown because its not a BGA chip. Unless its actually a solder ball under the RAM chip or the CPU that is damaged and the tapping in this area is actually causing the shutdown. I have tapped on the RAM chips themselves with no shutdown. Not sure what to do here. Should I try to reflow the RAM closest to U7600?
Thanks
Don't use your finger, it may shut down because you are conductive and messing up U7600 regulation. Poke the board with plastic tool and see if it is the same. Else it is just the common 3662 issue.
