820-4924-A No Backlight
machelper
Hello everybody;
I m working on 820-4924 (Retina 13" 2015) no backlight problem, No liquid damage or drop. Tried another known good LCD and data cable.
- F7700 = ok and 12.5V
- Replaced U7700 nothing change
- BKLT_EN_R = 3.3V
- PPVIN_S0W_LCDBKLT_R 12.5V ok
- LCDBKLT_EN_L is 12.5V ( it must be low i think)
- PPVIN_S0SW-LCDBKLT is 0v
- SMC_LID = 3.32V
where can i check next step?
Check data lines continuity from LCD connector pin 3 and 4 to U7700. Check voltage on pin 8 on LCD connector.
Hi again ;
I tested board with know good 2015 LCD and cable also no backlight. When checked PPVOUT_S0_LCDBCKLT to ground resistance its 72ohm is it normal? İ think its too low
Where can i check next step?
