820-4924-A Not turning on 2015
maazkamani
Liquid Damage Macbook retina 2015
green light no power
ultrasonic cleaned and made sure it was dry
plugged it in and while measuring smoke came out of the board
q7560 had a hole in it
replaced it with 2013 board (slightly different part number)
anyways same thing just the light nothing
pp3v3_s5 is not constant on L7560
ppbus_G3H is 12.57
Q7560 was obviously dead and U7501 is dead too likely. There is also a good chance the 3v3 bus went high due to the shorted FET. What is resistance to GND on L7560? Replace U7501 if resistance looks ok.
maazkamani
ok so i injected voltage to that pin and other connected components. nothing getting hot
removed l7520 and short gone. i thought it was the coil. i was obviously wrong
p5vs3_vsw had the short rail
removed q7520 and short gone
now replaced that, and u7501
now getting 3.3v constant and cpu getting 1.7v
but nothing on display with brand new battery plugged in
feel so close but yet so far
Bleh :(. Give the board a good inspection for corrosion, but I suspect 3V went high. There is so much stuff on the 3V rail that it is not practical to fix this.
maazkamani
No image. Solid black. 5v on the bklight
i know these things have low heat but not fan spin either
and Caps lock doesn't light up
