821-3115 palm rest sensor
rlowe215
Im back with a 821-3115 board.
No sign of water damage.
Fans spinning at full speed.
Test in ASD EFI shows error in:
Sensor - Temperature (Ts0P) Palm rest
Test in ASD OS shows error in:
Thermal Interface - Processor Error 255 heatsink
Temperature (Ts0P) Palm rest Error 13005 SMC can not read sensor
Temperature (Ts0p) Palm rest error 1 Unable to read sensor
Done so far:
Tested new trackpad and new trackpad cable
Disconnected everything from card accept keyboard and trackpad
Checked R5270/R5271
Checked pin 17 and 19 on J5800 shows 3.3V
Checked all pins on J5800 for short
What to do next?
Too much difference. Remove R5923/22 and check again. After that there is only one thing left on this bus and that is the SMC.
I assume you inspected trackpad connector/iSight connector and SCM area carefully for liquid/corrosion.
