hi
got a 820-2936 board. board got liquid spilled.some or bit on u2800 q5030 r7551 ( those areas)
board power up but missing CPU VCORE.
checked on U7400 PIN1 VRON 3.3V PIN2 0.5 PIN 40,24, 15 are around 5v
should be good to go , but no CPU VCORE,replaced U 7400,Q7550 Q7520 already. same thing
one hint i found out was diode mode on pin 1 R7555 was "0" , i measured on another board is around 500-600.
so i think either u7400 or Q7520 is bad, i replaced both. then checked, back to normal around 500-600
but once i connect power, no CPU vcore, then disconnect charger. check again later, back to "0"
kind of confused with that and stuck now
any advice would be appreciated!
thank you!
thank you!
