A1278 820-2879: No power // no green light
SamMac
Hey Everyone!
Got a 2010 MBP, no sign of liquid damage found.
No green light.
PP3V42 is present.
PPBUS_G3H rail is not present.
Checked resistance around each component with the PPBUS_G3H and all seem to show 0.24 Ohms (in 20K setting).
Not sure what to check next or where to go from here.
Thanks,
Sam
SamMac
U6900 - 0V all round
U6901 - pin 1 (SMC_BC_ACOK) shows 0.01V, PP3V42_G3H shows 3.40V and all other pins show 0V.
Not sure how to check continuity, SORRY!
Resistance to ground on both ends for L6995 shows around 51.0 (on 200K scale).
SMC_RESET_L seems good (all components showing 3.4V)
Thank you!
ACOK is missing so that is a problem. Check R7005 and voltage there, also check R7021/22/51/52. If any of those are dead then also replace the ISL.
SamMac
Okay so ISL replaced, green light shows but fan doesn't spin and PPBUS_G3H showing 0.46V. R7005 shows 16.75V on both ends now.
Pins 17/18 flactuating alot not able to get a stabilised measurement.
Pin 27/28 also flactuating.
Should I still also replace R7005?
SamMac
Replaced R7005, R7051 and R7052 and its giving the same issues.
PPBUS_G3H still giving different value of 0.53V.
Forgot to mention but getting 3.24V on SMC_BC_ACOK and 3.4V on SMC_BC_ACOK_VCC.
Anymore suggestions or would you like any more readings.
Thank you.
smiba
To be sure, are you measuring these resistance values with power applied or not?
Also see dukes response above
SamMac
CHGR_DCIN: The voltage is 16.75V
27/28: gives 20Ohms
17/18: gives 0 Ohms ---- i'm gonna check my R7051 again, its giving 0 Ohms and not giving 2.2 Ohms and the R7052 is giving 0 Ohms aswell.
I am measuring resistance without power applied.
Thanks, Sam
Gurmon
Thanks, Sam
Seems like corroded/broken traces to me. Inspect circuit coming out of pins 17/18
How can corroded tracks cause a lower resistance?
R7052 is supposed to be 0 Ohm. R7051 is the one that causes the 2.2 Ohm reading.
