A1398 Display Problems 820-3787
RyanLEN
Hi. I have this machine that a shop technician forced the LCD cable in crooked and broke a piece off in the LCD connector. I have change the LCD connector and tried with known working LCD/cable with the same result. Sorry for not leaving any measurements. I had to leave early and wanted to ask in your experience is this repairable? Thank you in advance.
Never seen a resolution issue like that. Did you do a PRAM reset? Tested with a known good LCD?
Also when this is back running take it to Apple for a new LCD under the coating recall.
