A1466 820-3437 No Backlight
Tony Tone
Liquid damage around U7701. Replaced: U7701, C7714, R7741, R7715, R7731. Just a tiny bit of soy sauce got near this chip. Ultrasoniced.
C7714 5V
C7711 3.3V
R7731-1 8.57V
R7731-2 2.8V
R7704 1.46V
D7701-1 8.5V
D7701-2 21V
Lid 3.4V
New LCD assembly same.
PRAM Reseted
Image present
it should be 25-27v. BKL_PWM should be 3.3v you can try taking a jumper from pp3v3_s0 to the BKL_PWM that will set it on full brightness permanently
After a PRAM reset should be about 3V on BKL_PWM (full brightness), on boosting I have 26V......... I say bad backlight driver, but also check connector.....
Probably the U7701 then? I've been using pulled ones reballed with an iPhone stencil. I have some on order, but impatient. Thanx Philip, I'll try this jumper !
And thank you for clarifying the voltages ! ! !
3rd LP8550. Same results. All of these come off donor boards though. I may have to wait until the new ones come.
