a1502 missing L7430 (PPDDR_S3_REG_R)
elcapitan
hello i got a a1502 that was touched by another shop. it shows green light on the magsafe but it doesn't turn on. After visual inspection, i saw that it was missing a inductor L7430 on the line ppddr_s3_reg_r. could this missing component cause a bigger problem (i.e frying cpu)? i tried to find a donor but i wasnt able to find one with similar specs.
It should show an orange light. L7430 was removed for a reason I guess. First thing to check would be a short to GND on either side.
elcapitan
got the fan spinning and chime after replacing l7430 and isl6259. Now i need to figure the image problem. im waiting for a new lcd
elcapitan
No Title
it's 2015 model.the board number is 820-3476. im pretty thee lcd connector is no good. it looks like a piece dismissing on the left side. Is it possible to change the lcd connector without replacing the entire assembly?
JohnB8812
820-3476 is the 2014 model not the 2015 model. And yes you can replace just the LCD cable very easily on Retinas just have to remove spine.
