Anybody Have experience with alienware? LA-C912P rev 2. plugged in not charging.
I have been fussing with this one, for a bit.
2 replacment batteries,
flashed bios.
known good power adapter.
On boot the bios indicates that the battery has experienced failure.
in windows the battery shows very little info in battinfoview, but windows reports it at 100% charge.
will not boot with battery only
powers off if power adapter is unplugged
uses bq24780S as a charging chip.
im getting 3.3v on acok
19.1v vcc
19.4v acp
19.4v CMSRC
25.2v ACDRV
2.6v acdet
0v IADP
33mv battpress
3.3v TB_STAT
220mv BATSRC
250mv BATDRV
no charge indicator lights.
no voltage at battery connector pins when battery is plugged in with new or previous battery.
No power coming from the battery would either be another bad battery or a short on the main battery bus.
Don't these dell "Smart" batteries also require a signal from the board to actually turn on the actual battery power. I am not seeing any short on the battery bus. and this is the second battery i have tested on this computer.
