Jay
Hi Folks,
I got the PPS2116A power supply and am having trouble getting magsafe plugs to work with it.
The magsafe cable only has two wires in it, one is + and one is GND, when I connect it to the PSU and set the Voltage and Amps as printed on the original power brick the cable was attached to... no magsafe light, no charge, nothing. The Mac works fine (using a beater MBP in case I blow it up) and with another normal charger, no issues.
Up to this point, any mistakes I've made in connecting, Voltage or Amps setting?
No experience with an external power supply so very much still in the learning phase. Any help appreciated
