Circuit board heater, your favorites?
I have looked around there are two types: Spot heater (from under) using hot air via 1" or 2'" dia "round salt shaker holes" or planar heater (many types) that heats over large area of PCB. Is spot heater I thought would fit the bill?
Goal for our SMD rework for repairs, using hot air and hand solder irons in order to have heat requirement lower and easier to work with especially the power planes and less stress to the circuit board components. So soldering can be done at less heat setting with soldering irons and hot air around 375-400 instead of much higher and time spent much less during soldering.
Idea is: Spot heat PCB to 100C or so, and work on PCB easier. My wish is handle typical larger cellphone PCBs and would be nice to handle notebook and computer motherboards, cards board for any repairs.
We already have iphone sized surface heater and works rather well for iphones but too specialized for anything else.
Don't forget about the microscope height and chairs height issue too as the heater requires PCB held at much higher height than sitting on the mat.
Cheers,
G.Beard
Cheers,
For board repair I find it's just not needed. OK so some parts of some boards need a little more soak time but since I have a source of hot air in my hand, and I'm able to actualy move my arms, I just use the reowrk station, along with my elbow for distance. Spending money on what you can do for free is probably not the best way to go about kitting out your lab. A good example is those BGA rework stations with split vision positioning systems. An extra £4000 for what you can do with your own eyes!.
When working on a board, you can see exactly when you have the right tempratures. Messing about with dials on a pre-heater, and dialling it in just right, is far more time consuming than intuitively knowing what to do with the rework station in your hand. I find I simply don't need 2 sources or heat for soldering a QFN or 0201.
However, given the reviews of some other equipment, I would probably buy a QUICK pre-heater, if I found the need for one:
https://kaisertech.co.uk/catalogsear.../?q=Pre-heater
https://www.somersetsolders.com/qui...MI-ryq-8zV3AIVz53tCh2oqAAUEAQYASABEgJ3OfD_BwE
As for surface area, IR or forced air, I have no idea.... Just wanted to put in my 2 bob.
The MOST important thing you said IMO, is working height. I no longer have full feeling in the bottom of my legs due to a trapped sciatic nerve. If you want to spend money on something, spend it on making sure your posture is good, and your heights and possitioning are fully adjustable. Heat the board with the station.
