Clover EFI Hacintosh bootloader bricks 3332 MBP 15"
G.Beard
So I just got a machine in. Customer was hackintoshing thier Windows machine and during creation of the installer the installed Clover to the MacBook SSD. This resulted in corrupted EFI. I've replaced it but I'm wondering why this happened.... Would it have written some sort of fucked up variables to NVRAM?
Fresh chip has fixed it of course.
PRAM reset by the way, would not work because it would chime loop before ending the full chime. Anyone want to guess?
A "fresh" chip will probably have a ME problem now! Read original chip and fix the original ROM.
What happened no one knows.
G.Beard
I cleaned the ME already.
Chip from exact same spec board wth clean ME.... Unless there is something else I am unaware of?
That method is totally wrong and does not transfer over all the custom settings of the original Apple ME and just uses the Intel default ones. Open both ME regions in FITC and see for yourself.
SMMRepair
In addition to what duke said above, several of the "clean" BIOS dumps over at GH's repository are corrupted/bad. Just an FYI. Have confirmed this myself several times. Also, even some of the "clean" ME region blocks for some models that you download directly from Intel are bad (or more correctly, they're "clean", but "clean" is not always what you want to repair the BIOS on these units, and they can cause issues). Best to always stick with the ORIGINAL BIOS. For some reason people think taking a BIOS dump from a unit, then cleaning the ME and changing the serial number results in a "clean" file. Not the case.
G.Beard
Oh shit! I've ben using that for ages!
Where can I find a actually good guide?
EDIt: never mind. I will read through the intel guides.
Fuck me, it would seem I was missing a LOT.
Get the FITC for your ME region and compare ALL the settings of the original ME and the "clean" ME. Probably a 100+ things that can be changed.
