Good way to get SMC's?
bjf
I don't have the time or will to buy boards from China and pull and reball the SMC's so I'm trying to find a good path for reballed SMC's. I have a growing stack of boards that all need SMC's - mostly 2015 Airs and 2015 13" Retinas. Does anyone have a good method for buying them?
nate8organic
duke is right there is no other way to get smc from the right board model. and even if you could its not going to be much cheaper than buying a whole donor board to use. if your know how is there you can pull and replace without reball most of the time. i don't even own a stencil for smc. if time is really of a concern have an employee pull and prep the smc's for you in bulk, its really not that time consuming 30-60 min max for a smc replacement @ $300 + board/repair...
bjf
thanks, that settles the debate. any tips on pulling without having to reball? that sounds much more appealing.
