Hdd sensor iMac 27
MDY
A customer asked me to replace his iMac 2011 hdd 1TB with SSD and told me that I should replace the hdd sensor also, as fan will speed fastly. What he mean? I dont see hdd sensor in this model.
I read about and seems that fan will speed fast randomly. Any solution for it?
iambehr
Any iMac with the separate cable, whether it has a temp sensor or a plug for the HD can be safely bridged. The SMC will just read the HD temp as 0 degrees and keep the fan at normal speed.
iambehr
I solder a bridge at the base of the hd temp connector on the main logic board. Note that you must be careful to not drop excess solder across the board anywhere. This only works if you want the fans to spin at low speed all of the time. If you want them to spin faster you must use a fan control, as the reported temp is now always 0.
