I want to add an SSD to this imac but keep the hdd too inside, does it matter the SSD is connected to the optical drive slot with a ssd caddy, or the SATA slot where the HDD was connected? is it the same speed?
The easiest would be to just throw the optical drive and install the SSD in the converter caddy, unless it is a slower SATA connection than for the HDD.
