Imac graphic compatibility
Belive all but the 2GB 6970M in the late 2009 27" Core 2 duo. (the 1GB card works)
Also id shy away from using The bigger cards like the 4850 and 6970 in 21.5" machines, i dont believe they will work (due to heat and power consumption, i dont think any 21.5: imac will take MXM 3.0 type B, only MXM 3.0 Type A)
Please correct me if im wrong.
No you buy a 2010 27". You can insert cards in those without taking the board out if you remove the bracket. 2009 21.5 cards are the only ones that will ONLY work in a 2009 21.5. The rest is all interchangeable.
