This machine has image, but no backlight.
I replaced the LCD connector to restore image
Backlight is on pins 38,39,40 (image)
In the schematic, those 3 pins are the same line
In the image, pins 38, and 39 are connected to a pad, however there is a gap between the pad and the wire on the motherboard.
Does the signal go out pad 40? Or do I have a pulled pad.
Thank you
Thank you
