Late 2013 Retina 13" Screen - No Video
bjf
I have a late 2013 Retina 13" that works fine with a good (but cracked) screen but I'm trying to repair a screen that had some damage to pins 1 and 2 and very slight damage to pins 3 and 4 on the LCD-side connector. After adding solder they all looked good so they were just covered with melted plastic. I replaced the connector and have a backlight now, but no video. I was extremely careful so as to not damage anything around the connector when removing it. Pins have all been double-checked - they're all solidly soldered. I have a known-good cable. Any ideas what could be happening with the signal once it hits the LCD?
aprendiz
Moderator
You mean pins inside the display assembly??? If yes, how do this happen?? Shorted cable??? I guess display is trash now.....
If there is backlight the LCD must work. Remember that 2013+ machines boot to a black screen with just backlight. After 30 seconds you should get the question mark. If that does not happen I suspect a bad LCD assembly.
Try with a known good assembly first.
bjf
Yes, that was my thought and why I'm trying to save this. The backlight is definitely on. The original cracked screen works fine when I hold down the Option key. It goes right to the drive select screen. When I attach this screen and do the same thing I get just the blank screen. And it never goes to a blinking folder. It just has that dark blue/black screen that normally comes up on these models. To be really sure I booted it into a system and hooked up an external monitor. Still nothing on the screen. Built-In screen is recognized normally.
