MacBook 13" 2017 820-00840-A Wateer Damage
ohannis
Hello,
I have received a MacBook 2017 820-00840-A it is not powering on due to water damage. where should I start diagnosing from ? when I plug the power in should I get power readings or i have to jump start it to get readings ? if i need to jump start what pins i need to jump start ?
Thannks
ohannis
U have checks U5420 Pin 4 and 3 for PPBUS_G3H there is no power reading there do i have to jump the system to get power?
ohannis
F7000 Has no Voltage
R7020 broke off when i touched it, what board uses the same R i can remove from to reuse ? :)
Pin 2 on R7020 is 5.25V
Only the newer board use those type of resistors, so from 00045 and newer. Get some donor boards 00244, 00875 or something.
ohannis
Jut got some Boards Replaced R7020 still there is no power on F7000 R7020 pin 2 has 5.25V. i think the PPBUS_G3H is not coming in. any comments ?
You think PPBUS is not coming on? Why not measure it?
Where was the original corrosion? Any around the CD3215 chips?
ohannis
Duke;
here are some readings
PPDCIN_G3H @R9920 Pin 2 has 5.3 volt
C6482 HAS ZERO VOLT
PPVIN_G3H_P3V3G3H 0.2 VOLT
R7075 HAS 0V
HOPE THIS HELPS IDENTIFY THE ISSUE
