Hi macbook turn on but issue with kernel panic ,try to mount USB with ASD 3S155 but getting kernel messages also its very hot around U3600 ,will upload the image of kernel panic screen
If U3600 gets burning hot it may be fucked, they normally get a little warm but not finger burning. There is not much to loose with a kernel panic board so if in doubt pull U3600 off and see if it works again. Thunderbolt we can live without!
I am really out of ideas on this one. There was obviously a voltage spike on the thunderbolt and this could have damaged pretty much everything. Also removing the TBT stuff should not cause the fan to run high so I have no idea what happened there. You booting EFI version of ASD?
