Macbook Pro Retina 820-4924 Not Turning On, Liquid Damage
PPBUS_g3h 12.60v
PPBUS S5 HS COMPUTING 12.60v
PPBUS S5 HS OTHER5V 12.60v
PPBUS_S5_HS_OTHER3V3 12.60v
PPBUS_S4_X239 missing 0V
PPVIN S4 TPAD missing 0v
PP3V42 G3H 3.42v
PPVRTC G3H 3.34v
PP5V S5 5.01v
PP5V S4 missing 0v
pp5v_s3 missing 0v
pp5v_s0 missing 0v
pp3v3_s5 missing 0v
On u7501 Pin number 4 P5Vs3_Enable missing, I tried to trace back where it creates, found it on on page 64 after R8179, that resistor is fine , missing PM_SLP_S4_L now I am stuck here to look further
Please adviced, I attached pictures where it was liquid damage
Already changed u1900 but no difference
Thanks
omg never seen anything like this
If battery is connected macbook turns on and works fine
I plug charger while battery connected works fine, disconnect battery while it is running still works well, restart computer without battery , it will restart fine , it just not turn on without battery, after turns on i can disconnect battery no issues :(
JohnB8812
Disregard anything I said before. Does the Mac charge the battery? If so, then make sure you are using a known GOOD 60 or 85 watt OEM magsafe 2 charger. The 2015 Macs I have found are very finicky depending on the charger you use. Sorry for any confusion from before your post on the battery confused me when I first read it.
Green/orange light present? Using at least a 60W charger? You should only have a REAL 85W charger for testing as all MacBooks will power on from 85W.
