Mid 2010 1278 Kernel Panic
RyanLEN
Good Morning - I have a Macbook here with constant Kernel Panic. Passes ASD. I have changed RAM, hard drive and SATA cable with fresh install. Thank you in advance.
Check the piece of tape on airport connector. Remove the metal sponge thing on the cable it will short out the pins if the tape is missing. Make sure to use only PC8500 RAM.
BTW. I know you said its pretty much done. Any thoughts just for my information on what may be wrong with it beyond repair?
I'm not trusting the Corsair memory, put is something else. Besides that it could be too many things, I have no idea where to start. Disconnect everything non essential too of course.
