Missing management engine
G.Beard
Hi.
History
This is a recycling centre machine, already worked on.
Was no power
Replaced Q7130 and some other badly done bit's I can't remember.
Problem
Board now powers, hangs on boot.
Fans running high.
ASD (EFI) says management engine missing, Ts0P error but Ts0P returns nothing on the schematic
This is SPI ROM issue right?
G.Beard
If you want you can search the file for "SSN" or "ssn" and change the serial in a HEX editor.
OK thanks. I'll find a hex editor for OS X.
Also, let's say hypothetically that I get a board in with a shorted CPU high side and I want to replace the board. If read the chip, search for SSN, I can then change the serial on the new board to the one on the MacBook base right?
