I have a sad pile up of 15in + 17in MacBook Pros, 2010, 2011 and some 2012s with GPU/VRAM issues.
CAN GPUs and VRAM be upgraded?
Will the lead (Pb) solder improve the reliability over "lead free" ?
(Or is there some other reason as to why GPUs started going bad so often?)
Are there any ways to distinguish between a bad GPU vs BGA balls connecting the GPU?
Is it better to replace the GPU irrespectively?
Or is the issue primarily the BGA connection, and not the GPU itself?
Should the VRAM be replaced by default?
Can VRAM be upgraded?
We've also had symptoms that're identical to a bad GPU ... which turned out to be the VRAM!
Can the 15in 2010 i5 use more than 256MB VRAM?
Can the 15in 2010 i5 use faster VRAM than GDDR3?
Can the 15in 2010 i7 use more than 512MB VRAM?
Can the 15in 2010 i7 use faster VRAM than GDDR3?
Has anyone tried GDDR5 or larger amounts of VRAM on this or other Unibody MBP ?
Can the 15in Early 2011 i7 2.0 GHz use more than 256MB VRAM?
Can the 15in Early 2011 i7 2.0 GHz use the 6770M GPU ?
Can I use the 6770M GPU in ALL 2011 MBP when we replace the GPU?
Can the 15in Mid 2012 i7 2.3 GHz use more than 512MB VRAM?
Can the 15in Mid 2012 i7 2.3 GHz use the 750M ?
Can the 2009 or 2010 be upgraded to USB 3.0 ? or is the controller on the Southbridge or something equally impossible to replace?
THANK YOU to everyone who helps make progress in solving these questions; I know you earned your knowledge the hard way. I get that the 'data cost' would be many many hours to acquire what anyone contributing here has already spent.
I am truly grateful.
