[SOLVED].001 Current Sense Resistor look like this?
Status
Not open for further replies.
macitech
White and Silver?
no polarity I assume?
Thanks
They come in all sorts of colors and sizes, green, black, white. Check board view and schematic for the value. Should of course the same physical size you need. It actually has 4 pins, the 2 small ones go to the sense circuit.
macitech
Thanks Duke!
Machine is up and running.
Doesn't look pretty but it works.
Had problems soldering the resistor on but used the heat station with the air flow way down under 20%.
Now I have to clean the board and put it back together. Still praying all is well.
Thanks Again!
Status
