[SOLVED]820-00163 chime but no picture
ielectron
this was wine damage, i can only see a bit damage on the left side on the board, above the lcd connector (but not close to it)
I could not find schematics or boardview for this, some one can send it to me please?
i cleaned that area, dont see liquid anywhere else, but actually the board smells like wine.
So after cleaning, SMC, PRAM reset, there is chime, fan speed up, if i remove the touchpad fans speed up as they should. so it seems alive but no picture, or on the external monitor.
Not sure if that is the board with the typical GPU voltage controller issue, but anyway i resoldered the voltage controller chip with soldering iron only, same thing.
For start i really need the schematics and boardview.
I don't have the 00163 either. LCD connector area should be close enough to 3662/3787. Check for a 5V pulse on L8300. Need to check while it is powering on as there may be only 5V for a second there while it chimes.
