SOLVED - 820-00165 - Not Charging Battery, although shows charging sign and runs off a battery
it-solve
Got this A1466 with shorted PPBUS_S5_HS_COMPUTING_ISNS C7313 Tantalum Cap and F7140 Fuse. Now turns on and works on Battery. It Shows Battery Charging but pulls under 0.6A and does not charge the battery. After draining the battery, is now not charging it anymore. Tested another charged battery, and shows the same symptoms.
Had slight corrosion on SMC_REST_L line, replaced R5100 and resoldered C5495.
U7100 Voltages (on a Batt and Charger) seem fine. Placed them on an image hopefully for easy reading.
Any Suggestions?
